flatheadgary
i have put a 318 into my '63 Belvedere and am having problems understanding the throttle rods.
according to the manual, you hold the trans lever all the way forward and tighten the nut on the linkage down. first off, i have a stock 318 bracket for a two barrel and i put a 360 4 barrel intake on. which required me to make it taller to align with the carb. now that wasn't a big problem, i just had to lengthen the rod that goes down to the bell crank on the bell housing. i will have to bend and lengthen the one that goes from there to the trans,as it was a floor shift part and is straight. now for my real question. the slotted rod on the carb to the bracket on the manifold is what 's got me stumped. how does it push the trans lever back if it rides in the slot until it gets to the end? let me reword that. i can see where the carb will push the rod back and the rest will push the trans lever back. then whats the point of the slot? why not just make it exact length? or does the carb linkage go further forward than the slotted rod? what i would really like to know is how long is the slot? i don't have that rod is why i am stumped. i do have a part that is slotted and can make work if i can know how long the slot is. thanks for any replies
