HYRDGOON
- 2:53 PM
- Apr 20, 2013
- Breslau, Ontario, Canada
Hmm, that is interesting.
I have been mulling over turbo(s) or centrifugal setup. A big question I have is reliability of the centrifugal on a street car, for example the d1sc? I seem to find a lot of used ones listed online that "just came back from rebuild".
I have had turbo cars, screw type supercharger cars, but have no experience or no friends that have ran a centrifugal, since I am considering trying one out I thought I would ask here. How reliable are they on a street car, mild boost, 8-10 psi? How drivable are they with a blow thru carb setup?, throttle response ect?
What you're proposing is exactly what I'm doing. I have a D1X that will be running through a C&S 933 CFM Blowthru aerosol (awesome for drivability I've been told) on my Stroked 440. (522 crate) and plan to run around that 8-10 psi (BUT NEED TO LOOK AT THE WHOLE PACKAGE AND WHAT I WANT TO ACCOMPLISH AS ADVISED BY HEMIRUNNER)
The smaller blowers are very reliable and drivable. When you get to the F series blowers they are insanely loud on a big HP combo and make long hauls really annoying. If set up right, throttle response is instant. The SBF we did goes from idle to John Force burnout in a fraction of a second.
I'm waiting for the "Mad Max" version of this!!
Mad Max version meaning you can turn it on or off? lol! I'm glad to hear that opinion of the F Series because seeing all the big blocks run F's I get a bit curious if my D series is up to the task but what I'm attempting is relatively mild (compared to the big boys) so I think it's probably the better choice.
I wish I was closer to you to give you the $$ and let you handle the build details... so much to absorb!!
Damn interesting for sure, helps for freewheeling & less backed up boost & pop-off valve issues
especially with boost when getting out of the throttle, cool idea for damn sure
Thanks for posting that...
I thought it was pretty cool too Budnicks! Solves that problem of the cogs being hard on the head unit from harsh start/stop yet gives the positive traction without working about slip with a serpentine.
As you would say... "Me Likey!"
Cheers!
