Proper progression
Ken Milton
9:10 PM
Canada
Is there a proper progression I should fallow with rebuilding my car? I know I will have to replace most of panels on the back of the car, and one inner front fender. So is it ridiculous to do the hood this year, the front fenders next year, etc, etc, etc. Or do all body work and paint the whole car at one time? I want to drive it in the summers and take it to car shows.
Generally speaking, yes all the body work and paint is done at the same time. I wouldn't take it apart till I was ready, had the time to thrash on it, and the money to do it right.
All depends....of course it makes sense to do all the bodywork at once but some restorations take years, meanwhile you're getting older, the world is changing etc.
If it's not a show car but a good driver you're after, then doing it piecemeal and driving it all the while is a great idea.
Mine's been on the road for 3 years now but I'm still working on it (refreshing the interior at the moment). I had my hood repainted a few years back as a standalone job (to fix some screwholes from the scoops being in the wrong place). I can't stand it being off the road for more than a week or two at a time. I just want to drive it as much as possible.
Thanks for the views, I think I will just drive it this year as a survivor, doing little things on it and then really spend the time next winter doing bodywork on it. With the amount of backordered parts, I should have all the parts by then.
Like the saying "how do you eat an Elephant" with the answer "one bite at a time", tackle the car. Its easier to keep control if you do an area/section at a time. If you plan on upgrading suspension/brakes, wait until you have all the items in hand, then get after it. Do you have any floor pan/trunk rust to deal with? If you do, the interior needs to come out for that job. So, what about replacing the carpet. any upholstery work, frame connectors, wiring upgrades/changes etc in those areas? You'll want to address stuff like that when you are in a given area as its out and you are already there. Opposite of the thinking states/municipalities do when the re-surface a road then come back in to put underground utilities in and jack up the road. For my stuff, I start at the inside areas first and cut those down to sections to tackle. My car is mostly gutted and I'm dealing with engine compartment first. When it gets closer to paint time in that area, I'll pull the doors off as I'm going back to the original color. The jambs will get stripped as will the back of the doors. That way those inner areas are already done, paint wise and I won't need to pull the doors later for paint. When those areas get dealt with, I'll get into the middles of the car to do the structural upgrades. Frame connectors, torques boxes etc. There will be some overlap into the back area so the cut/modify/weld operations will all be done at that time. Cuts down on re-do's. Your outer body/paint stuff, to me, should be saved for last and not done a piece at a time spread out over weeks/months/years. Like painting a room, start in the back and work your way out, not into a corner.
Excellent advice. Thank you
