413 belvedere
- 10:53 PM
- Jun 22, 2016
Seems to fit good in lower one, now quite as Good in upper, am thinking it pushing right on edges of upper and causing it to break throughYes that appears to be a problem. How does the pushrod fit in each one. I could see if it fits tight in the upper one there could be some binding going on an viola popped rocker arm. There is a difference between small and bigblock rockers. But I am not 100% sure what it is whether its overall length or if it has to do with the diameter of the cup on the arm itself. I think you are on the right track.
