IQ52
Cam specs......which include recommended parts.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1497&sb=0
Valve spring 911-16 single w/damper........925-16 dual w/damper
1.524" o/s diameter.................................1.509"
1.110 i/s diameter................................1.125"
Inside diameter of inner...........................0.697"
Spring rate 373.......................................395
Spring height/psi
1.950/104................................................92
1.900/122...............................................111
1.850/141...............................................131
1.800/160...............................................151
1.400/309...............................................309
1.350/328...............................................329
1.300/346...............................................349
1.250/365...............................................368
Coil Bind 1.200"........................................1.175"
Were Comp Cams lifters used in this build? If so, which ones? Some of them require the used of adjustable rocker arms. The 822-16 can be used with stock rockers. The 867-16 required adjustable rocker arms.
And the 107 lobe separation decreases the piston to valve clearance.
Spring height/psi
