QA1 K Member with torsion bar setup looking for anyone who may have experience with this setup
ruready67
1:24 AM
Santa Clara
I have 1970 Mopar B body setup with QA1 front suspension.
first stage I did
QA1 upper control arms
struts
Tie rod end links
new ball joints
pitman arm small sector
wilwood front disk brakes
I ran the car for 4 years all good.
Second stage did
RB 493 full roller Motor
QA1 Tubular K member with
Hemi Hodgkin's Torsion bars
QA1 Lower control arms
Borgeson Power steering Box 14-1 small sector
Bergman auto craft no cut steering coupler
KYB Shocks
Was getting ready to take car off jack stands go for a test drive was checking steering
turns to passenger side all the way to lock position turn all the way to driver side to lock position and out side tie rod goes over center and binds
My trouble shooting disconnected center link from pitman arm check steering action full rotation both sides no binding. check steering box had proper ratio 3.5 lock to lock 1.75 Back to center
tried new small sector Pitman Arm
I exchanged the Borgeson Mopar Power Steering Boxes 800126 small sector
QA1 K Member with torsion bar setup looking for anyone who may have experience with this talked to both Manufactures all say they only tested with OEM Parts
first stage I did
struts
Tie rod end links
new ball joints
Second stage did
KYB Shocks
I can’t help with any of that but I will say that I bought a Qa1 K-Member off of Summit years ago and one of the mounting holes wouldn’t even align up to finish bolting it up to my car. I got my money back no problems from Summit. I run Qa1 upper and Lower CA and strut bar and like them but that K- frame was junk. I didn’t realize how low the sway bar mounted either but they’ve been a few members mount them through the k-frame if i remember correctly.
would deffenitly not recomend QA1 or Bourgeon As far as customer support and standing behind their product Both acted like i was trying to get a refund even after I told both was not looking for refund was just looking for trouble shooting help they just wanted to play hot potato with my problem. Also QA1 K member had minor fitment issues No way i would recommend
Well what bothered me with QA1 was how arrogant they were when I called them about about the fitment issues. Its like they held zero accountability with the problems. Asking me has my car ever been wrecked and all kinds of stupid crap. Now with Borgeson I bought a box for my car in 17. I installed it but only got to put Im guessing 200 miles on it. I then got called on a almost 8 year job away from home and got to drive the car very little. I then started driving the car some and it started leaking out the bottom. I called borgeson and talked to them and yeah I know its out of warranty now but they basically admitted to me that they had some problems out of several of their boxes that year with a casting flaw and mine fell in that range of boxes and it was resealed by a borgeson dealer for a just incase and it still leaked but guess what? No offerers to replace it or even give me a discount or anything from borgeson but thats my fault I guess but I will say Peter Bergman has went over and beyond to help me out, so my props to him.
Mr. Bergman was awesome helped me trouble shoot several things one had nothing to do with him spent time to try to find possible solution sent a link to a competitors web site wer i might find the part his customer support is beyond excellent Top shelf.
Update In California could not wait for the rain to stop went in my drive way in a puddle of water tested the toe out did not get anything perfect but good enough for a test drive and the alignment shop.
Full disclosure I am not a mopar guy BB 67 Camaro is my Boo was just using the 70 B body as my daily driver but that RB440 had so much love time got hooked cant stop F with it when **** went south with the QA1 was just rying to get back to camaro
Have to say still may have an issue with the whole set up but really feel like I moved forward thanks to your comment
Gotta love the tech support you don't get after you've plopped your money down. Maybe next time tell them you're Mark Worman. They'll probably trip over themselves showering you with help.
