Hello,
Hate to publicly admit my knowledge is seriously lacking, but it is.
I have recently purchased a project car for my son and I to play with (a 73 Charger) and we are making good progress. My current problems are one with brakes, one with a transmission leak and lastly one with an oil pan issue. The car is running and driveable but needs improvement.
Question 1 for brakes. The car has the original drum brakes all around. At slow speeds (under 35) all is well. When one gets to around 50 or so and you apply the brakes, the car jerks right then back to the left. I believe that is just an adjustment with the pad spacer but have no reference point to go by to ensure they are both adjusted correctly.
Question 2 transmission leak. Car runs good and when I park it no issues. 3 days later after not driving the vehicle I get a pool of transmission fluid. No easy trail to see where it came from. Any suggestions?
Question 3 oil pan. Car came with a 360 that I am pretty sure is out of a pickup. The previous owner cut the pan in half lengthwise, removed some height and welded it back together so it would fit in the car. It now leaks and I want to replace it. Can I just purchase a stock 360 pan to replace it and/or do I need to replace the pickup for the oil or not?
I apologize as my knowledge is not where it should be to do all of this but thank you for any advice.
