Quick couple of questions
65AzBel
10:41 AM
Prescott, Az
I recently bought my 65 Belvedere I Sedan (well traded 2 motorcycles) but I need a little bit of help.
1. Speedo: It doesnt work because the the cable isnt hooked up. Its not hooked up because the engine and trans (318 and 904) is out of a Magnum. I know I have to buy a new speedo gear, but I can't figure out which rear it has. From what I can tell its a 10 bolt with the bolts on the front of the rear.
2. Brakes: It has drums and I'd like to convert it to discs with a boosted master cylinder. Besides Other B-bodies, what other set ups would fit.?
3. Service manuals: Where can I get one?
4. Parts sources: Anything besides Year one?
5. Tail Lights: The ones I have are very oxidated and cracked. What else could work and where can I get them besides Ebay.
You probably have an 8.75 if the configuration is like a Ford 9", loads from the front. If it's missing it's tag (should be a tag under one of the nuts with the ratio stamped in it) then just rais the rear, and rotate a wheel watching the yoke. Count how many times the yoke goes round for 1 turn of the wheel
You could use 73 up A body discs. Very common swap. Or go aftermarket with Wilwoods, or SSBC, or even the scarebirds. Scarebird sells a bracket and tells you what off the shelf GM parts to use. It's an inexpensive swap
Any of the vendors should have one. Might post in the "wanted" section here
The last two questions I'll let one of the guys who is working on a 62-65 answer. They will have a better idea for you.
Thanks Runner.
Actually I compiled a Gripe sheet that covers all that I think needs work. I'd like to get the bugs worked out before I start using it as a daily or long distance cruiser
Gripe Sheet:
1. Vacuum Lines (how many are there?)
2. Bushings (Is the polyurethane the way to go?)
3. Choke for Carb (Its got a holley with automatic but its not hooked up, is there a way to convert it to manual?)
4. Alignment (its got a lot of negative camber)
5. Gas tank filler neck gasket (looks origional and its shot)
6. Push button climate (only heat works)
7. Vent Window Hardware (it looks like a banjo bolt, I cant find it anywhere)
8. Dash Lights (Before I open it up, what size are they and how many?)
I suggest that you hook on to the 62-65 Mopar website. There's a lot of great info there. You can also join their email clubhouse, there's a link at the bottom of the site. Those guys can answer all of your questions.
Since I got an extra 273 that needs work, I started to pull it apart.
The reason it was pulled was it was burning 1.5 qts per 100 miles.
The heads are good, 1 slightly rusty intake valve.
However 3 of 8 cylinders and pistons are rusty. After the engine was pulled it was stored in a garage with the plugs out.
Since I know I have to rebuild it, should i reuse the pistons or go new?
