archangel
I am replacing my engine wiring harness. The new one came with the gray (w/tracer) wire in the bundle. The one that connects to the coil and terminates in a single spade connector by the firewall bulkhead connector. Required for a ralley dash tach.
My car, '70 Bee (w/383 HP, single 4bbl), did not come with a tach from the factory, just the clock. My old wiring harness, factory original, does not have this grey tach wire. True, the wire harness tape is missing so the wires are bundled using a combination of wire ties and plastic flex tubing. Certainly possible that the tach wire was there from the factory but was stripped out at some point since it was not used.
The factory parts manual seems to indicate that there was only one engine harness part number, 2983808, for my application.
Striving to be true to the factory, was there was only one engine wiring harness used (which included the tach wire) regardless of whether or not a tach was ordered? That seems to me to be the logical approach which would have allowed for either a factory or dealer installed tach.
Does anyone have the factory harness, car ordered w/o a tach, with the spade connector just "hanging" by the firewall bulkhead connector?
