Orig69
- 2:58 AM
- May 16, 2021
- Toronto Ontario Canada
A standard breaker protects the wire, not the outlets or the appliance plugged into them.So, I’m okay with the 15 amp receptacles and the 12/2 wire? You guys have me worried now.
They need to be 20amp receptacles and fed from GFCI breaker if in a garage. Looks like you ran 12-2 RXNot sure, I’m not an electrician either. My buddy that is an electrician told me that was all I needed for my use. Lol. I hope he was giving me good advice.
He did run 12 wire, tough getting 12 wire on 15 amp receptacles some times. Depends on the braker he used.15 amp recepticals are the cheapest and lots of folks just run the cheaper 14 gauge instead of 12 gauge wire. Most rec. never see a full 20 amps for long periods of time except for maybe commercial and industrial shops. For home shop use most folks are easy and the 15 amp rec. last for years. Use heavy drop cords and pull on them roughly, the cheap rec. break/bust easily.
Say what????You do not "need" to put 20A receps on 12G wire.
...but you DO "need" to put 12G wire on 20A receps.
I was taught, if you run 15 amps from the box, you run 14-2 with ground, from the box to the outlet with a 15 amp outlet, period. For a 20 amp, 12-2 with ground, one end to other with a 20 amp outlet. I'm not an electrician, but I've played one for 40 years. 20 Amp receptacles are more expensive than 15 Amp receptacles, which is why people some people will use 15 amp outlets on their 20 Amp circuit. But is it acceptable, , it is perfectly okay. The topic is controversial. Some experts say that the practice is dangerous. I follow my local code and the advice from a few friends that are electricians and one that has his own business. I don't mix and match different material. That just me.I'm not a electrian but why 15 amp outlet instead of 20 amp.
@kiwigtx
You can’t put 15amp receptacles on a 20amp fed circuit. You certainly can put 15amp receptacles on 12 gauge wire but needs to be fed from a 15amp breaker.I was taught, if you run 15 amps from the box, you run 14-2 with ground, from the box to the outlet with a 15 amp outlet, period. For a 20 amp, 12-2 with ground, one end to other with a 20 amp outlet. I'm not an electrician, but I've played one for 40 years. 20 Amp receptacles are more expensive than 15 Amp receptacles, which is why people some people will use 15 amp outlets on their 20 Amp circuit. But is it acceptable, , it is perfectly okay. The topic is controversial. Some experts say that the practice is dangerous. I follow my local code and the advice from a few friends that are electricians and one that has his own business. I don't mix and match different material. That just me.
