That was me a few years ago...
Static bonding
Like I said, nope.Everyday work - 3 phase pole replacement
Lol.. we got 500 pins yesterday and found that even though we are spot on for OE size the smooth pins are trapping air like pistons and you can't push them in. #1 Son did another test run with the holes slightly bigger and now adding a strength champer to the glass hole boss. Print in process for another hundred. Previous run works fine with rough rusty oe pins.Two sets please. Lol
What if you drilled a tiny hole through there, to let the air escape as the pin was pushed in?Lol.. we got 500 pins yesterday and found that even though we are spot on for OE size the smooth pins are trapping air like pistons and you can't push them in. #1 Son did another test run with the holes slightly bigger and now adding a strength champer to the glass hole boss. Print in process for another hundred. Previous run works fine with rough rusty oe pins.
