REAR END QUESTION
zigs
12:14 PM
Yakima Washington
I have two rear ends #1 is a 64 Belvedere 8 3/4 clutch style sure grip (355)
#2 is an Abody 8 3/4 cone style sure grip (323). I want to swap the two third members
any problems here. The Belvedere has the adjustable right hand axle. I want to switch just the third members not the axles
I forgot to mention, due to too many beers, that you may have to buy conversion u-joints, if they are different on each third member.
Thanks that's what I thought just making sure. I didn't know if the inner roll pins would have anything to do with it.
The thrust spacers are a different design between the clutch and cone sure grips, but they are the same length.
The spacer in the cone unit can't fall out. The spider gear pin goes through the middle of it. The spacer has a slotted hole in it so it can slide back and forth a little.
Thanks. Its been awhile since I put them in for got how I did it.
'64 Belvedere would have taper axles originally.
You are putting the cone type in and taking the clutch type out ? If so, why ? The clutch type is the superior one.
