Rear sway bar
Yes. The only un-sprung weight added would be the brackets mounted under the shock plates.
Thanks, I have decided to order the Firm Feel kit. I like that there is less unsprung weight, but mostly that the sway bar is mounted up high and out of veiw
how really can affect the bar weight on the ride to be actually worried about the unsprung weight ?
if is something to really worried, nobody should use bigger rims and tires either. ( Just thinking out loud )
You are correct except lighter wheel and tire combinations will improve ride quality. You should ride in my 94 2500 with a Dana 70 rear axle and the difference will become clear. Every little bit helps.
Mike
Yes, I guess, but... I think 98% of the ppl never thinks on that when talking about tires/rims change. Maybe just 10 seconds car owners LOL
