Rear view mirror problem
Dcreole!
12:41 PM
Ohio
My 72's mirror is loose front screw is tight. Every time I hit a bump, mirror moves at the ball... Solution ? image.jpg
You need to take the base down and tighten the the retainer plate that holds the ball of the post in the socket of the base.
I drilled a hole in a mirror from a windshield mount and used a long screw to mount it together...it wasn't my proudest fix but it had been stripped in side an wouldn't tighten up on 2 screws and had a hideous PO fix .... I will get a new one at some point....
