- 10:44 AM
- Jul 1, 2015
If you can find an 8 3/4 or Dana housing that is perfectly straight after 40-50 years of use, buy a lotto ticket. I narrowed my buddy’s D60 truck housing that has 3/8 wall tubing and it was slightly bent. How did I know it was bent? I have a center less ground bar and machined pucks to go with it. It was off an 1/8. Also before I started narrowing housings, the place I went to told me “no housing is perfectly straight”! Now if you bought one from Moser, Strange, etc., yeah, they are gonna be straight.
You mentioned you narrowed your friend's D60 truck housing but did not say how much you narrowed it and it was "slightly" bent. Just how much is slightly?. You made a GO-NO GO gauge out of a centerless ground steel rod and machined slugs presumably turned on center with respect to the rod's center line, to try and measure axle tube TIR (Total Indicated Runout). I would think that the shorter the axle tubes are in length the less influence there are on the outboard axle bearings offset loading. And more importantly do you check for side to side axle shaft flange parallelism while rotating the assembly? And if more then 0.003" - 0.004" TIR, how do you "fix" the issue. Just curious.....enquiring minds want to know.....I case I want to check my D60. Thanks in advance for your help.
Bob Renton
