Rebuild cost breakdown?
satellite66
2:13 PM
Jamestown, RI
Just wondering what the average cost of an engine rebuild is. I have a 383 engine disassembled and would like to rebuild it. Not sure what steps to take next. I guess it's the machining (honing and leveling). About how much does that run?
It can vary quite a bit by: geographical location; how well known the machine shop is; etc. A friend said he had a stock rebuild done in SC for around $1,900 including 'some' parts. This was sending them an assembled motor and getting back an assembled motor. I'm guessing no pistons/ cam/ valve changes...just bearings, rings & seals.
I am into mine for about $4,500.
My total machine shop bill was $2,290. That included:
Disassembly
Hot tanking everything
Bore to .040 over
Polishing the crank
R&R cam bearings
Assemble Pistons to Rods
Some port work
Cutting/ lapping for larger valves
Installing hardened Seats
Assembling heads
Balancing the lower (rotating) assembly
Probably forgetting a few things as well. When he was done, I was left with installing:
Camshaft
Crank bearings & crank
Oil pump
Piston & rod assemblies
Timing chain
Heads
Lifters & push rods, intake
And of course all covers, pulleys and oil pan. Assembling myself saved me $325.
Parts were another $2,200+ that I provided.
It will depend on your location mostly, but you should be looking around $2000 to $3500 depending on what you are doing to it, and the brand of parts. Aftermarket parts can make the price rise exponentially...
Thanks for the input. Yeah I'm not sure what I want to do with it, and I don't have a car to put it in right now. But it's been on my stand for a year or so now (maybe two years?) (it came as part of the deal when I bought my Satellite) and I figured I should rebuild it (or have it rebuilt) and then figure out what to do with it. I was hoping i could have a little done to it at a time so I wouldn't have to interrupt my other projects.
i normally have several eng laying around ready to be rebuilt.no need to play with it unless you have something to put it in.final resting place can determine a lot of how you build it up.
Couldn't agree more.
I know, or am pretty sure my engine has a forged crank. How do I determine what cam it has?
Rebuild Breakdown from a well known PA rebuilder for my 440 (2007 rebuild date)
Valve Job 210.00
Install Guide Liners 168.00
Resurface heads 70.00
8 V 1386 Valves 53.12
8 V 1900 valves 64.48
16 S 2970 seals 17.60
16 Manley Retainers 46.00
16 805-DO springs 82.50
16 Pioneer locks 746/766 4.90
Cook Block - Strip 95.00
Bore & Hone w/plates 310.00
Ck Align Bore & Deck n/c
Clean Block - C. Brg & Plug 75.20
Press Pistons off 12.00
Recondition Rods 125.00
Pin Fit and Install Pistons on Rods 59.00
Clean, Cut, Chamfer & Polish Crank 139.00
Balance Assembly 210.00
MK 632D w/cam Upgrade (32918) 672.14
ARP Rod Bolts 56.20
8 L2266F Forged pistons 496.32
__________________________________
Total 2966.96
You can learn to do some machine work yourself. Kits are available reasonably to check for cracks. I use dye penetrant because it work with ferrous and non ferrous metals. You can also hone your own cylinders. I have everything here to do basic valve jobs as well. I also have a cam bearing tool and can remove and install my cam bearings. You can also install your own freeze plugs. You can knock a nice chunk off your machine shop bill if you're interested in doing a little work yourself.
Thanks for the info clemul and Rusty. I don't mind doing work myself but wouldn't I need some experience at doing machine work? Is it hard to hone the cylinders? Doesn't that have to be done precisely?
It does. It's one of the easiest things to do as far as machine work, though. Of course a ball hone a chimp could do, but a rock hone does take some practice.....still very easy to do right.
