Rekindling the passion
OzCharger69
9:42 AM
Australia
As much as I hate admitting it, I haven't been driving the Charger much at all. Over the last few years, "Stevie" has always been loyally sleeping in the garage and as the faithful car it is, always starts and runs without hiccups. She turns heads and she always makes me feel proud. Recently, I dedicated most of my time restoring and riding vintage motorcycles. Over the years the Charger accumulated a long list of small little jobs - sloppy steering, window splashers not working, disabled horn because it was honking when I turn the wheel, emergency blinkers not flashing, Dixie horn stopped working, exhaust leaks and on and on.
So how best to rekindle this passion than getting all dirty again. I bought a stage III firm feel box and PST poly suspension kit+ adjustable UCAs 3 years ago and never installed them, so it was time to pull the dash and the front end down. I have now done most jobs which were quite straight forward. Currently waiting on my welder mate to weld stiffening plates to the lower control arms. A lot of the steering slop was coming from the coupler, only to find that the shoes were installed incorrectly.
Can't wait to finish up, take the Charger to an alignment shop and start enjoying her more often!
Thanks for the post - that's a really nice ride! She looks ready to play.
So are the bumps and dings called Stevie Nicks? (Sorry, couldn't resist.)
I remember you.
You used to post over at the Charger forum. I haven't seen you over there in awhile. Didn't we chat about the Borgeson steering box and an overdrive transmission?
I go through points where I am not so motivated. It helps to have friends around that have old cars like me.
there can only be one Stevie. It was a hard decision between her and Johnette
I remember you.
I sure remember you too. Is the other forum still alive? I can't remember chatting about the steering box but I remember chatting about the Tremec manual conversion.
Oh yeah, I remember now...the Tremec.
The forum over there really dropped off after Covid. I would have expected forums to at least hold steady after some people formed friendships online.
There are two dorks over there that follow me around to criticize my posts there, no Moderators ever show up to discourage it either. I do what I can to stoke the fires and keep the forum alive but man is it a losing battle.
Another small problem I found, the chassis mount for the spindle of the LCA came unwelded.
If you can weld, you can fix it.
the front end is back together. Rough alignment done with a string line and a spirit level before taking it to the alignment shop on Monday. The car handling is night and day difference. There is zero play in the steering and the stage III firm feel box is such an upgrade over the stock box. Can't wait to get it aligned.
As for alignment settings I was considering suggesting the following to the mechanic
1/8" Toe in
CASTER 3-5 degrees whatever I can get
CAMBER Negative 0.5-0.75 degrees
Thoughts?
