Removing pinion gear while axle is in a car
vintage chromoly
8:59 PM
ohio
hello all.
I’m going to be helping a local friend change the gears on his strange 60. The axle is in the car and I don’t want to remove it to work on it.
How are you guys pressing the pinion out when the axle is in a car? Are you guys using a dead blow hammer and just wacking it out? I’d prefer to not hammer on it, if there is a tool to press it out?
I’m considering building a tool (kind of a saddle) to press it out with a bottle jack.
The carrier will not be a problem and I won’t need my spreader as the strange has adjustable pre load collars as opposed to shims.
Thanks for any help
Use a hefty punch and ball peen right in the dimple in the end of the pinion. It won't hurt a thing, lately I've been using my air hammer with the pointy bit. If your changing the gears anyway why worry about damage to the old ones ?
Thanks for the reply.
The old gears have about 30 passes on them. I’d like to not damage them.
