moparjohnny
Did you let a kid carry the plugs for you?
He didn't tell you he dropped 'em.
well i did not need a case of beer,but i could use a few right now,guy came over to look and found that the spark plugs are not getting fire,i did what you said and he looked and agreed that was right,reason for not cranking not timing,there is no spark at all,never had this problem before,the ecu is orange and old,distributor wires are brittle and weak,i was going to replace all that stuff,so now i will have to,thanks for all the help.I hear that, Darthomas!
Fought for two days, trying to figure why last V8 I built wouldn't run right. Checked everything ignition wise, timing, so on.
Wound up my brand new set of spark plugs...5 of 8 were cracked...and wouldn't fire right. Real head-banging on that one. Would have never dreamed.
