Reverse Detent Disassembly
rstockbridge
8:52 PM
Mason, Texas
Can someone please explain the best way to disassemble the reverse detent assembly? I've heard horror stories of guys dropping the ball in the ball into the transmission, so I'm hoping to avoid that.
Also, is there anything special to re-installing the assembly?
Take out the inner hex plug from the plug in the casing. Remove the spring and use a magnet to get the ball out.
Now you can remove the case plug.
