Roller bearing idler arm for 65
BigFlo
2:39 AM
NJ
Anybody know if anyone makes a roller bearing idler arm for a 65? Google doesn’t turn up anything that I’ve found. Nothing from Bergman, Moog, PST.
I see it for 65 C-Bodies but not B.
Thanks guys. I’m guessing it’s this kit? How was the installation and how does it perform?
That idler uses a stud to mount to the K. Even though the roller kit eliminates the play in the arm itself, it’s still mount on a single stud. 68 and later went to captured style which is much more stable.
One of the reasons I'm using a 70 k-frame in my 65. Double shear mount for the idler arm.
I’m not familiar with the different years and features. I’ve got a 65 with a 65 kframe.
what is a double shear mount?
What is a captured style?
With what I have, would there be a benefit to eliminating the play in idler arm itself? Seems like it would eliminate 50% of the play?
Here is a picture of the 70 unit I'm using. Compare that to the 65. Double shear is what you see in the pics. Both ends of the bolt are secured. On your 65 unit, the top of the bolt can move around, only the bottom is secured by the mount.
