I'm assuming you already knew the extra cost involved with a roller setup. There are many advantages to a roller cam and lifters. Among them: No question the cam can take more load with a roller lifter. As the roller cuts down the friction on the cam (hence less loading) the ramp profiles on the cam can be much steeper/quicker than a flat tappet lifter can accommodate. This allows for very modern profiles to be used, profiles that been developed in very recent years as cam technology has advanced. You already have adjustable rockers, so if they are in good condition that will save you some money. Valve springs are generally roller cam-specific, but on a 15 year old engine you'd be wise in changing them anyway. Yes you may need a few items to complement a roller cam, but if you are looking for a large power increase I'd do it. You don't mention what heads you are using, but if you are looking for substantially more power, a good bumpy roller with aluminum heads with a c/r around 10.5-11 to 1 will really make a difference. Of course a bigger carb and headers will be mandatory too. You don't mention a budget you want to stay within (maybe you don't care about the cost?), so I may be advising you with ideas that just aren't in your budget. Even changing nothing but the cam you have to a modern grind could gain you some power I'm sure. We all know that to get more horsepower it takes money, no way around it. How do I know? My son and I just finished his 440 adding Edelbrock E-Street heads and a Comp roller setup on his '70 440 motor. It had small chamber ported '67 440 heads on it before with a solid flat tappet Comp cam, and it ran high 11's. With this new setup he's not run it at a track yet, but the power increase by the seat-of-your-pants is noticeable. Cost? About $5500.00 CDN. with freshening up the bottom end as well. So it's all gonna depend on what you want and what you want to spend. Sorry to make this so long-winded, but the bottom line is, yes, a roller is a fine choice in my mind.
