Rotors for four piston calipers
Jon Erickson
12:59 PM
CT, USA
Anybody know where I can get a set of four piston caliper rotor for 69 Charger I heard the year ones are not reliable with the machining specifications because they’re made overseas sometimes they don’t clear the caliper sometimes they hit the spindle. I checked out the ram man but they seem awful expensive. Are there any other reliable sources?
You can try Craig, if i remember correctly his screen name is @mobilparts ... hes a great guy and will probably have what you need, he has treated me fairly and honestly every time i buy from him...Rich
Try NAPA store. The last I bought was a few years ago and I got what they called loaded calipers. Calipers and pads together. It was for a 67 GTX.
I didn't need rotors.
Unless your doing a restoration I'd change to a more available disc brake conversion setup. You could buy a really nice kit for what it costs to use them, don't toss the parts if you change to a kit.
Are they too thin to have turned? A lick off both sides and Bob's your Uncle...
They are pretty beat up but I’ll check the thickness. Yes going all stock. Had to take off original pads to restore them. Car has only 50k on it
The should still be plenty thick. Mine are the big single piston Kelsey-Hayes ones on my Bird, where original and had never been off until I did them late last Summer. 56,200 miles and only needed a light lick to clean them up.
dadsbee is right the catch is find somebody to take the time to cut just enough to clean them up.
Thanxxx for the shout out, Rich....
I have N.O.S. Rotors --- just plates now though....
No more Hub & Rotors Assemblies.... And I have
LEFTY and Righty Front Wheel Studs..... And a few sets ONLY at the moment of N.O.S. ++ Asbestos ++ Brake Pads *** CRITICAL ***
You don't want to rip up THESE Rotors to smithereens.......
Going to see if I can get the rotors turned first I have a friend with a lathe but will be interested in a set of studs for both sides 10 R and 10 L With nuts if you have them. What Do you charge for rotors? I have a brand new set of Pads.
