Anyone reading this have an extra stock fan you'd like to sell ?
While your at it throw that flex fan away. They are dangerous and are known to come apart.
My 69 318 Charger had an OEM fan clutch.Point the IR gun at the thermostat housing to get a true temperature reading. Definitely add a fan shroud & I believe all you need to know (on a stock radiator) is 22" or 26" wide (you probably have a 22"). I "think" the clutch fans came out in '73, but don't quote me on that. New fan clutch for sure. Yep, swap the water pump (heck, they're like $35 only). Cooling system flush too (I had a "good looking" radiator what was plugged up). Also, maybe take off the radiator cap & warm up the engine to look inside the radiator for an occasional "big bubble" (head gasket). Radiator cap was a good idea (15lbs. stock I believe). And yes, distilled/deionized water + "water wetter" or similar runs cooler than 50/50, which reminds me, if you have 100% antifreeze (not 50/50) that can make a car run hot too, so pull out that little "floaty ball" or "floaty lever" hydrometer & check your coolant blend.
Get your radiator boiled out, throw away the flex fan, install factory fan, clutch, and shroud.
I don't know when the fan clutch was introduced. Yes the Charger was factory dash a/c. Odd thing was the car had a 4 bbl carb & it was definitely an OEM installation. The car was an absolute stocker. However, nothing shows that Mopar rolled out 318's w/ 4 bbls.Thanks! So when/where did the fan clutch start in Mopars? Did your Charger come with A/C? This is something I'd be interested in knowing.
Yeah, it was a 69 & was obvious that nothing had been changed out on it. i also had a 69 Coro 500 & a 68 post Coro 440 that were 318's,,,,both were 2 bbl with non-clutched fan.What the heck? What year is that motor? I "thought" 318's only got 2 bbl.'s until some late '70's early 80's (???) cop cars, but what do I know?
Great minds think alikeYou must have read my above message. LOL
