TheSwede
Hi, I have a Holley 850 dp on my 383 as a tryout and it was running great until yesterday, car runs good at idle and part throttle but when I press the pedel more than 50 % it is loosing all power and runs on 5 cylinders, releasing the pedal and in runs good again.
This problem came over night and the battery was disconnected, fuellines are new and filter too. Plugs wires etc are all new.
The only thing I have done is that I mounted a smaller air filter and got a carb poff, otherwise it is all as yesterday.
Could a blown power valve cause this?
I will try it with the old larger air filter to see if it helps.
Suggestions?
Carb?
Coil?
Distributor?
Car runs good revving in neutral, responding is nice, it is only in drive it will running like crap.
Suggestions?
Carb?
Coil?
Distributor?
