seam sealer?
74charger07ram
7:00 PM
Weatherford Texas
When I took the old trunk floor out there was seam sealer between the floor and the tail panel. Do I need to put seam sealer back between the two before I spot weld? This is on a 74 Charger
No you would seam seal after you weld. Unless you use a resistance spot welder ( there are some weld through glues and seam sealers for those ) if you mig weld you would have a big mess on you hands not to mention it would probably catch fire. use a good weld through primer tough.
What he said.
