Seams !
99ss
12:34 PM
Oregon
What's the best way to do seems?
The factory spot welded them together and then used sealer.
When I mate stuff up to be welded should I try and emulate what they did or just weld the seam and then seal.
On the other car this is what I did but I am wondering if I should do the spot welds instead?
You weld the car together solid it will ride down the road like a buck board. You want a little bit of flex in it.
The factory uses resistance spot-welding, something you're not able to do. Plug-weld with a MIG. In some areas, you can consider adhesive, either Fusor or 3M. Being old-school, I never used the glue until a few years ago, but it's great.
Thank you, I was thinking the flex was needed but really wasn't sure
