Mason
Alrighty! I'll post what happens tomorrowCorrect!
You don't want to overfill it!
Keep checking the dipstick!!
Do not overfill!
Let us know what happens!
Merry Christmas!
Do not overfill!
Merry Christmas!
Here's to hoping you post a link to a YouTube video of you smoking the tires!Alrighty! I'll post what happens tomorrow
If torque converter was not filled before install it will be difficult. The 9.5 qt is for drain an fill still have almost 2.5 qt in tc. So 13 qt on a rebuild.best to have car 4 wheels off ground and level operating temp fill run through gears NOTE brake before putting trans in park
Keep doing till full. Drive light accel should shift out of first18-22mph sec 35-40.
I need to jack my car up and see where this leak is coming from, its alot bigger than you may think, looks like a quart of fluid on the ground and the levels werent overfilled. These knocking noises were hard and hurt to listen to, but would only happen in drive and reverse.that click could be driveline slop or maybe leaking check ball in the valve body
there was one we used to leave out but doing so gives full pressure in reverse so you get a big clunk
on the drip
either coming out the overflow or you have a leak
If anyone can help me out on this one I'd really appreciate itI need to jack my car up and see where this leak is coming from, its alot bigger than you may think, looks like a quart of fluid on the ground and the levels werent overfilled. These knocking noises were hard and hurt to listen to, but would only happen in drive and reverse.
Thanks Wild R/T Merry Christmas! I took a little vid of my trans while i put it in reverse and saw a leak spurt out of a line when i put the throttle down a bit so i found that problem out, but I said screw it and finally pulled into the driveway but the knocking didn't get any louder...real confused on this one because nobody else seems to have my symptomOn your "Leak". The engine needs to be running & the trans in neutral when you are adding fluid, otherwise it doesn't get pumped into the torque convertor & the fluid comes out the vent.... Making a huge mess.... Good Luck, you'll get it...
Oh, Have a Merry Christmas!!
No I promise the converter is all the way seated because I screwed in a bolt with a wrench on it to keep it from moving out of place, so im positive i set it in all the way.May be way off target, did you put the trans back in? Are you sure the converter was fully engaged in the pump? Usually if not you can't bolt the trans to the block & still turn the converter freely. If its not engaged properly with the converter into the pump, maybe? Really unlikely but....
To clarify I had a wrench on it when i was installing itNo I promise the converter is all the way seated because I screwed in a bolt with a wrench on it to keep it from moving out of place, so im positive i set it in all the way.
