FOR SALE Slant HEI mounting plates
HALIFAXHOPS
MSGT(ret) and MOPAR only distributor rebuilder!
9:09 AM
Halifax, PA USA
Feedback: +141 / =0 / -0
I have some slant six HEI mounting plates made by the Fabulous Ritchies Garage. Asking $40 each to offset Machining costs. I also have NOS HEI modules with a proper plug to attach to a gm 4 pin. Also have all the components needed to make this up
Mounting plate with screws, and heat transfer past just need a 10-32 tap for the distributor housing. $35
10/32 tap $12
HEI 4 pin Modules $25
Power wiring $20
Pick Up plates with the HEI plug $45 NOS
.03 ohm HEI cannister coils $125 Petronix III Fit in a standard coil mount
Complete Refurbished Distributor assembly ready to drop in with a mild street curve with my custom springs (will list separately). $325 without a core 300 with one Look way better in person Just need a .03 ohm coil
And the actual ride
Any Questions just ask.
The BEST is the MSD # 83647 which comes with an adj built in rev limiter. It is physically larger than the std HEI module & has an exposed printed cct board. So it needs careful mounting in a protected area. Why it is the best is because it supplies 7.5 amps to the coil compared to 5.5 amps for the stock module. You need a low resistance E core coil to get the most out of it.
Also the petronix one seems to do well also. Run from the accell ones have a friend that oval races went through 6 in one season, all had the high dwell circuit fry when I tested them for him.
