I have a 26HP B&S engine on my zero-turn mower. Mowing the other day I heard a distinct change in the motor sound and more vibration, came on suddenly. I checked the deck, belt, pulleys, blades – all look good. More tripping found that the sound & vibration has squat to do with the deck/blades. Motor just sounds crappy at idle and throttling it up. Starts fine, no popping, missing (far as I can tell) and no knocking. I go through it every spring clean/gap plugs, oil/filter change, air and fuel filter, grease and lube. Took engine cover off as I hadn’t done this in a couple years (yep should have – lots of crap accumulated). Cleaned all that out. Checked the motor mounts thinking vibration there, nope, they’re tight. The PTO clutch was all of 4-thou out so readjusted it FSM specs. Has around 500 hours on it. Carb has never been serviced so thinking maybe it needs it; maybe skanked o-rings by now. Vibration though just doesn’t resemble a carb issue; not sure.
Anyone have encounters with this…ideas? Thanks!
