Brewzer67
Apparently my torsion bars are just getting a little too old for the task at hand of holding up the front end
I currently have an old set of factory 318 bars (despite running a 526" RB) that are getting pretty tired. I have cranked them up a few times over the last 15 years but they start to sink again after a while so it's time to get something a little more in line with the times and the other front end changes I have made through the years. All front end components have been replaced (polygraphite bushings, all new tie rod ends, ball joints, etc.). I switched to SSBC disks and have also added a fast ratio Flaming River steering box (no sway bar though). Since the torsion bars are a little weak, I occasionally hit the pan going over more "aggressive" railroad tracks, etc. I am thinking about going to a .0904 bar or bigger and am wondering if folks could chime in on what is working for them. I won't mind a little firmer but don't want to lose fillings. I do want it to keep the pan off the ground when I eventually (hopefully) lift the front tires on launch. I do run skinnies up front but may go back to something a little wider at some point but it will never be a corner burner.
Manufacturer and size recommendations appreciated.
