Herr_Poopschitz
But will a .020" difference in factory bore size even be noticed? I think we need to be looking at numbers in the .100" range - like a 413 vs. a 440 to possibly make that case. Even that might be a stretch. Also a good head shop can blend the chamber to make up some lost flow. Valve angles of the 426 hemi on the "small" 4.25" bore seem to fix whatever flow problems there might have been on that block so I'd put more stock in valve placement (or maybe porting) rather than a small change in bore size.
Yes it will make a difference. Air and atomized fuel see a few thousandths as a huge gaping hole. Flow a SBC or SBF head on a 4" fixture vs a 4.030" and they'll pick up cfm. An Edelbrock designer told me shrouding is why they went w/ a 2.20" intake valve on the Victors over the more readily available 2.25". It's why an LS3 makes significantly more power than a similarly built LS2 w/ 821 heads w/ only a slight increase in bore. There are plenty of examples out there...
Blending the chamber is not the same as deshrouding the chamber. Even deshrouded, the limit is still the cylinder wall.
Sure there are other things that have a 'greater' effect, but as you well know, EVERYTHING MATTERS...neglecting one thing in your engine program allows others to win.
