Speedo is okay but odometer doesnt work on my 66 Coronet
1965t5
5:09 PM
WI
I saw a few posts but all about when speedo and odometer are "broke". Is there a typical fix to when the odometer is not working but speedo is fine? I read in a few places about replacing the odometer, but is that at the speedo or the trans? Thanks!!
aha - so these parts are available from somewhere? Are the gears there unique to gear ratio in the rearend like the speedo gear?
as long as it's not a metric speedo, all should work
So where does one get these parts from?
you won't find new parts to buy, you will have to get a used speedo head and either use that or swap parts out to yours
Does anyone know what year and or model range share the same odometer parts? Do the A & E bodies fit?
