Kultin
Cant find the problem. Brake pedal is soft and spongey. It has been like that since i owned the car for 10 years now. Bought it with 4 wheel drum brakes and didnt run. Fast forward to when i got it running, had k member and front disc brakes from a 1972 charger. Rears were changed to right stuff disc brake. New master cylinder and proportioning valve were from the charger along with front brake lines. Pedal is soft and spongey. Can go to the firewall and doesnt have and end point. It will stop the car but will only lock up the front brakes on rock after fully pressing the pedal 3 times with each time gaining more braking power but still same pedal feel. Cass from doctor diff said to change the proportioning valve to distribution block and add a seperate variable proportioning valve. I purchased the recommended master cyclinder from Cass as well to help narrow problems down. I have bled and bled brakes. Even had some friends that are mechanics to bleed them as well to the same problem. The pedal rod with master work good in conjunction with each other. Do yall think I need check valves. I'm about to spend the best money and buy a complete brake kit, front and back with new lines because im tired of messing with this
