Spot weld cutter
Ron 73
Deceased, But not forgotton
Legendary Member (RIP)
2:39 PM
40th an Plum
Can you guys give a little advice on a good spot weld drill bit, I was looking in Eastwood and found these, i don't want to order a couple cheap ones and thought maybe you guys that have used them can give me an idea for a good one. I don't like to play the "pay me now or pay me later" with them, Maybe Eastwood isint the way to go but they do come recommended for quality stuff, but like any company they have the cheap and the good, i did promise to help my brother in law and i will need them myself so i need to get a couple good ones. Thanks.
http://www.eastwood.com/welders/spot-weld-cutters.html
this is the one i used it did ok
Blair all the way Ron...you won't look back. Both the skid proof and the spring loaded pilot work great (helps to use a punch with either). Buy their cutter lube or use a machine cutting oil/penetrating oil with them and you'll be drilling out spot welds like a champ. This is one tool you definitely do not want to go cheapest price shopping on (same for most tools for that matter). Makes a world of difference having a quality cutter vs. a Bargain City Sunday special.
http://www.blairequipment.com/Spotweld_Cutters/Spotweld_Cutters.html
Good luck
Blair is the best like Will stated. I drilled out 1 or 2 welds on my Charger project and wont use anything else.
I've done ok with these cheap 3/8" pilot point bits from a hardware store.
Blair is the best like Will stated. I drilled out 1 or 2 on my Charger project and wont use anything else.
I'm sure if I had the blair I'd never look back.
I suffer from terminal cheapness though.
lol!
I'm inclined to agree with that statement 100%
There's nothing quite like the best tool for the job. :grin:
I started using solid pilot bits years ago out of frustration with those old type fragile spot weld bits.
The blair looks very stout.
+1 for Blair. Works awesome, just make sure you get the premium rotabroach or better yet the little kit they sell. The cheaper double-ended ones don't last for $#!+ as youd probably expect lol
I really want to thank you all, Blair it is! Appreciate the help and responses, Blair must be worth the time and money being most all agree.. Thanks gentleman!!
No problem buddy! Hopefully it helps anyone else needing this particular tool!
Matt, ive been reading thru the "DOG" once again, i admire just how much work and time you've put in that bird! I know your busy, but id be a liar if i didn't say, im looking forward to the day the updates start again!!
x2 where's the paint?! :icon_thumleft:
