Stage VI - non Chapmans....what rockers to use
dsd1967
10:34 AM
Toledo
I picked up a set of Stage VI heads and the offset appears to be similar to the stock rockers. I was looking at some Comp Cam Pro Magnum roller tip rockers on Ebay but they don't appear to have any offset....at least from the pictures. Will these work?
Is there a recommended rocker for these heads?
Hey Dave,
Do you have a factory set lying around that you can toss up to check for standard offset alignment?
Yes I have a set of stamped rockers....good idea. I measured the heads and the offset appears to be approximately .250" but the factory rockers will verify if these are factory offset.
That being said, I still don't know if the comp cams pro magnums have the offset. The pictures don't appear to show it. I was wondering if anyone here was running these.
I think they are all standard offset on the intake unless you buy ones like mine....
That's what I was thinking. Mine are the standard offset so I know what I'll be looking for.
Thanks Jim
The Stage VI: *P4529335 Std. port & the *P5249579 Max Wedge port: Mopar Perf. Aluminum Heads are for use with std. offset rockers, even the big port heads say for stock valve gear
