first I should have included more info! Sorry. I have a 1967 HP 440. stock rebuild w/a Hugh's whiplash cam kit.new Jeg's elec ignition kit. new engine harness for elec, car is a 1968 Road Runner. 4 spd. we bought all new parts hoping to have no trouble. when we first tried to start it. it cranked and cranked and nothing. 3rd attempt I noticed a it hit at the end. so I started to just bump the key. this resulted in it starting. I have tried another ballast. and another ign switch. with the same results. it should start with the starter engaged? it doesn't seam to do this. I know very well sounds but that is what I am dealing with. I also checked current at coil. 1.06 - side (in run pos), and (5.71) + side (in run pos), and also checked 1.07 - side (cranking pos) and 9.16 (in cranking pos). also keep in mind the ballast I check with was off of a running car! and I tried 3 switches! including the OE one. and same results.
