steering 69 Charger
green1
4:02 AM
Orange Park, Fla
OK, no help on the first post, let's try this. Loose and wandering, but only when floored (hopped 440), TF. And this is from a 30 mph roll, doesn't seem to be spinning that much, just wants both lanes.
Car has been wrecked, with a tweaked kmember, caster is 0; that it? offset upper bushings?
Hmmmm, car was wrecked? Hit a curb perhaps? Sounds like you have a broken sleeve at the lower control arm pivot in the K member. Jack it up and take a pry bar and do some investigating. The LCA pivot has the stud with a nut facing forward and should not move at all. To repair you can either weld the sleeve in place or get another K member from any non HEMI V8 B body from 66-70.
