steering column
Not much to it. The bearing up top can be found, dig around a little. Rock Auto?
We recently discussed the lower bushing on the forum. Do a little investigation here.
Mike
GERST sells a bearing to replace the bushing in his kit. Reduces play and improves feel.
IMG_2227 by Greg Ault, on Flickr
Here is what I used for the bottom of the column tube , A friend made up some bushings that help support the lower shaft going in the box . It was made from some sort of self lubrication material . Was going to use a bearing but this was easier and better . I have one of the factory seals that go on the bottom if I can find it you can have it .
