RT K_line
What is the average stall speed for an 11 inch converter on a HP 440?
1950ish?What is the average stall speed for an 11 inch converter on a HP 440?
Thanks lew that's pretty much what I thought it's just that I wanted real world numbers from members. I have a 4200 stall now and also have a stock 11 inch core I can swap for a rebuilt unit. I'll post a question about getting my unit rebuilt elsewhere. I know the hub has a wear mark on it from the pump bushing But works fine with no leaks, I wold just like one around 3200 or so stall. I know I'm rambling but infomation is key to any build. I started out building a 290 plus duration engine and ended up with a 270 280 type cheater cam with 580 lift. It was a good deal at the time. Thanks for your input. I rely on our members for there guidance in matters I need information on.this really depends on the engines ability to make torque and the torque curve. there are no absolute numbers.
I was under the assumption that you were talking about FACTORY STOCK engines and converters. If you've made modifications, the numbers in the FSM would no longer apply.Its right there in your FSM.
