Any word on getting your S60? Date?Took advantage of Cyber Monday saved almost 300$ on a new rear axle
end assembly
Maybe it is the wrong way to go about it, but what I do is put an angle finder on the crank pulley of my motor. Say that would be -2.5*. And then do the same on the rear axle. Say that is -1*. Your pinion angle would be -3.5* total. I don't check the driveshaft at all.
In theory you are addressing pinion angle looking just these two things, and it usually works out if your rear end is in a somewhat stock location because the factory engineers designed the chassis and drivetrain with proper angles and u-joint phasing in mind. But there’s a reason your driveshaft has u-joints at both ends. The u-joints should be at equal and opposite angles, as well as phased opposite of each other to operate properly.
This video helps:
