Geoff 2
I am also trying to help the OP.
Carb companies like Rochester & Carter sized their carbs according to engine size, & designed their carbs so that the engine controlled the airflow it wanted....not the right foot. I am referring to devices such as air valves etc, that provided the additional air only when the engine could actually use it.
Two extreme examples of production engines that used oversize carbs...but did not bog because they had air valve carbs that added air in a controlled manner as dictated by the engine....is the Chrys Aussie 245 ci inline six & the 230 cu in 6 cyl Pontiac engine; the 245 had a 625 cfm Carter AVS & the Pontiac had an 750cfm QJ.
The Carter AFB came out in 1957 & bigger models had velocity valves in the secs to control air flow; similar operation to an air valve. Holley also got the message with it's vac sec carbs.
