sub frame connectors kit.
greenmachine
6:16 PM
portland
Hey guys and gals
I am looking at the full kit from UScartool for my 69 coronet. It runs 599.00 (minus shipping). My question is do I need the full kit? My motor should pump out approx. 600 ft. lbs. I've been reading some of the horror stories of not running sub-frame connectors and my car is a clean bare shell right now getting ready for paint.
I have the main 2 USCartool connectors running front to rear and they appear factory frame to the untrained eye. Don't remember the cost, but it was a lot less than that. They did the trick, no more cracked windshield. 500 at the crank. They are required on any B build outside of concours stock restos imo.
You cant go wrong with the full kit, or at least just the connectors!!!
The frame connectors well make a BIG Deference...But if you have the Money and the time go for it..you wont regret it !!
Its best to do it now when the car is apart! The full kit will give you the most benefit structurally with 600 foot pounds of twist.
I installed the torque boxes, frame connectore front sub boxes, upper front cowl braces, & front lower radiator support brace. Made a huge differance, took a lot of flex out! Check my thread in members resto's 69 GTX
