Sway Bars
BubbaMope
9:28 PM
Louisiana
I've done serious work on my 70 Belvedere recently. I put on a Moser Sheet Metal 8 3/4 rear end as well as QA1 tubular control arms. Only 1 problem. My aftermarket ADDCO sway bars no longer fit front or rear.
The tech guys at QA1 swore my front bar would fit but maybe he was talking about a stock factory front sway bar? My car did not come with one. Anybody know if a factory bar will fit the QA1 tubular lowers? Any suggestions for the rear bar?
Which AADCO bar to you have?
I have an ADDCO installed on the front of my 69 Charger and I just upgraded to the QA1 tubular controls arms as well. I didn't have any issues because the ADDCO bar attaches to the lower shock mount with a 90° bracket and the shock mounts stayed in the same locations.
If you're using the stock sway bar mounts then you'll have change to the later B/E body sway bar.
From QA1's website: Part #52308 is designed to work with the E-Body sway bar and the 1971-72 B-Body sway bar.
