Switch location recommendation
diesel_lv
5:15 AM
Arizona
I am installing a GearVendors o/d and it requires mounting a switch on the dash. I have a '67 Coronet and am not keen on cutting a hole in the dash. Any recommendations?
How about under the bottom edge of the dash, where the vent cables attach ?
It depends on how often do you think your going switch it on/off.
Back in the old days before cruise control was a factory add on we installed them and the on/ off switch clipped to the column shifter. Or micro switch at bottom dash
I want to use it just like normal cruise control. Put the car in drive and it does it's thing. No on n off
GearVendor has their own special switch. Cutting into the harness to change the type of switch will void the warranty.
Make a bracket and mount it under the dash using an existing hole. Even if you drill a new hole it's not that big a deal since you are not keeping the car original.
