Bob Sawyer
I've had a problem with my factory rally tach needle bouncing. Sometimes it will almost peg the gauge during acceleration. At idle it will bounce from 700 rpm up to 1500 and beyond.
I did a complete n & b restoration on the car, finishing it up last fall.
It is a 1968 Charger R/T, 440, 4 speed. Everything is pretty much stock with the exception of the electronic circuit board for the tach and the solid state voltage limiter for the dash gauge circuit.
The other gauges work as they should. The gray tach wire is connected to the negative terminal of the stock coil. I rebuilt the dual point distributor and it is all stock as well. The spark plug wires are the reproduction date coded wires sold by Classic Industries.
I'm looking for thoughts/ ideas on which way to go.
Has anyone experienced this problem?
Thanks, Bob
Thanks, Bob
