Wietse
Unless you have experience and tools leave the bushings alone. The pump should come with a new bushing. however I don't see a narrow bushing pump listed. If you can't find one contact me.
I've got pullers, hydraulic press and an assortment of puller/press bushings in a lot of diameters, for sure i could find something that fit to remove and install the bushings.
I measured the bushing from the front drum and stator surface it runs on and it was .001" or .0015" clearance IIRC.
All bushings look good so if they can be reused, i will.
Is there a tolerance limit you know off? I can add a set and in case i measure one that is beyond i will have to change it.
They have a correct year pump housing, incl. new rotors in the Used Parts section, will see when i get the order in what they have.
But in case of no availability i will contact you if you have something that you are willing to sell.
