coronet68mx
- 9:45 PM
- Sep 18, 2014
- Uruapan, Michoacán, México
Water in the gas?
You can also just open a bowl sight plug to check that without having to take the carb off. Gas will gush out if float stuckPull the carb and look to see if maybe
you've got a float bowl sticking.
Gaskets on the intake will be wet.
Same problem on my 440.
I think that jump wire is for neutral safety switch car won’t start if that not rightOP did not confirm the carb fuel bowls are full all the time.
Could be a bad pump (or pump push rod) and the manual adding of fuel sounds a little excessive and the spark plugs could be soaking wet all the time.
Just get another good battery and use that for the time being, let it charge when not in use.
Stay focused on air/fuel/spark as that is all what it needs, regardless of wiring quality. (but you need to sort that out later for sure)
If it cranks it means it is good, the neutral safety switch controls the start relay.I think that jump wire is for neutral safety switch car won’t start if that not right
Or the old school way using a cellophane wrapper from a pack of cigarettes!!You certainly CAN time the engine at 12* without the engine running with points ign. Very easy.
There is a couple of ways to do it, but easiest is with a DVM set to ohms, one lead grounded, the other connected to coil [-] terminal. Rotate dampener & when timing is correct, ie zero pointer lines up with 12* BTDC, reading changes from zero ohms to above zero [ points opening, spark generated ] as it passes through 12* BTDC.
