My plan was to get the whole tub sanded to 220 and with couple coats of surfacer on top of that for final prep,
Refine the jambs out to 600, shoot the jambs, and then evaluate for the next steps.
Soft masking is an art unto itself and I learned some ground floor, super basic things about it here on the jambs.
Getting the jambs into base/clear was another huge bump.  Having something shiny to look at after a couple years of effort
really helped.
After that, repositioned the car for final prep.  Although I am not sure it's necessary anymore with modern materials, I decided I wanted the ability to  "walk the car" (really:the sides) for orientation coat.  This being only my second metallic job and only third ever paint job,   All the work towards making it possible to "walk the car" is really towards avoiding the failure mode where the metallics aren't laying quite right.
Turned the car to allow that. Decided this would definitely be preferable to having the hoist in the way during the process.
 It does make it much easier to get around it, everywhere except the lower body
(It was alot more enjoyable doing bodywork on the lower areas, standing up with the car in the air) ....
Between the problems I had with the prior metallic job on the Polara (which I still remembered better than you'd think after 16 years), the couple test panel shots I'd done + doing the trunklid underside in the silver, and now having shot the jambs, in those experiences there is a wealth of learning facts about reducer and activator speed, gun setup, types of spray guns, spray technique, speed/distance/overlap/finer points, flash time, prep of the work area, air supply and air quality, and the list is almost endless.
Follow process to achieve a goal, 100%.....However, the human side of it that has to be physically learned is:
The underlying goal, for me, is to develop "feel" and intuition in the moment and not require constant active thought.
I could probably wax philosophical and compare it to being a musician and other things in life, because this is where the Industrial ART part of the work comes into play....maybe someone else out there understands what I'm talking about....
Tape used to block body lines, guide coat at every step/no exceptions, I found Mirka powdered guide coat to be a game changer compared to the rattle can lacquer I used to use.  I tried SEM dry rattle can guide coat on this project and didn't like it.
Quick process description followed so far, all using P grits:
Bare metal sanded to 80 before epoxy
40 used only for hardcore rust removal (trunk lid), and for hogging down over applied filler, and not much else
Lead seams same as original
Whole shell to bare metal/80
black epoxy, 2-3 coats
Polyester filler, block 80/150/220 (sometimes 320, I did the doors out to 320 when they were removed)
Epoxy again
Surfacer, block 150/220.  Make sure 2-3 more coats are added after 220.
(then the jambs were refined and painted)
Assemble the shell, align panels (Thanks for coming over, Todd)
Block the entire shell to 320
That's where the project sits in these shots.
@320 I found a couple problem areas to address, but overall it was looking pretty good.
