Yep. Thermostat regulates temp. Without one, in the heat of summer, it can run fast enough that the radiator cannot cool what it has.Absolutely
Agreed. Too cool and the fuel will pool in the intake. Higher temps atomize the fuel better. I personally run a 195People think cooler is better but it isn't.
The engine is designed to run at 180 - 190.
Too cold = wear.
I would suggest an intake manifold heat crossover blocking valley pan.
Really cool car you have I'd like to see it sometime.
That is one to keep entirely original as much as possible.
You should be able to change itSorry I've just noticed I voted No instead of Yes, what a dumbass!
Just installed a new high flow 160 thermostat per a school mopar mechanic I use for some of my work that I get done. Vehicle runs great. Does any know if mopar back in the day only used high flow thermostats only? I have a 70-71 parts manual and googled all the mopar part numbers for thermostats and all the thermostats look like high flow stats.
